Posted 4/18/2012 9:18:19 PM |
Last Login: 10/17/2022 1:15:19 AM
Visits: 747
IIRC, tim posted to his blog all of the specs of the cameras and monitors, and included links. Search feature on the blog might do it.
Posted 4/19/2012 7:21:18 AM |
Visits: 2,294
thanks. must have missed it. will look at it again.
Posted 4/20/2012 8:14:44 AM |
Visits: 2,294
Still reviewing blog. . . still haven't found it. . . back to looking. . . anyone remember which month the blog was posted?
Posted 4/20/2012 4:19:11 PM |
Visits: 3,119
It was Dec 10
he also has a search bar in the top right of the page if you need to find other info.
He has a lot more info on his blog and sorta quick updates here, If anyone hasn't checked it out they should lots of pictures and the occasional video. It has to be the most detailed build so far...
Tim Rocks
Later
333 HALF EVIL
Posted 4/23/2012 7:31:36 AM |
Visits: 2,294
your help is greatly appreciated.
Posted 4/23/2012 2:23:55 PM |
Visits: 2,294
for those with the limited search abilities like myself. . . . camera link
http://www.alibaba.com/product-gs/310970351/3_5_LCD_Rear_View_Car.html
Lots to choose from. . . Thanks for the great idea, Tim!
Posted 4/23/2012 9:56:48 PM |
They look like they're going to work out pretty well for me.. if the idea also works for others too that's great
They have a pretty wide angle lens on them and the infrared is really cool!!!
Posted 4/24/2012 9:42:23 AM |
Tim will you be able to use the black Plexi for your window then? Was you able to talk to your guy about the side mechanic tags in metal.
.Thanks
Posted 4/24/2012 2:34:59 PM |
I'll likely run lexan in the rear port holes with some window tint. It should let enough light in so that the cameras don't go into "infrared" mode.
I haven't had a chance to talk to my engraving guy yet.. but they do some stainless engraving which I think would work out well for those tags.
I've been sacked at work doing the whole nights and weekends thing
Posted 5/16/2012 12:56:52 PM |
Visits: 3,119
One issue you might have with the infra red is it may actually bounce back off the lexan and blind your cameras, I had some cheap night vision goggles if you got close to a window the light would create such a hotspot all you would see is a bright blob of green. one solution would to cover the cameras infra red and mount an external infra red LED hidden somewhere. Also you may not actually need the infrared, your not likely to be in total darkness ambient light should be plenty.. Later
333 HALF EVIL
