Posted 3/19/2012 8:19:54 PM |
![Forum Member Forum Member](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Forum Member Forum Member](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Forum Member Forum Member](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Forum Member Forum Member](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Forum Member Forum Member](Skins/CLTC20/Images/RankImages/BlockDisabled.gif) ![Forum Member Forum Member](Skins/CLTC20/Images/RankImages/BlockDisabled.gif) ![Forum Member Forum Member](Skins/CLTC20/Images/RankImages/BlockDisabled.gif)
Visits: 6,742
Tim, is this because mainly because of the fuel cell you chose? In other words, is there a way make the fuel caps functional using a different fuel cell? ![Keaton](http://www.chickslovethecar.com/board/Skins/CLTC20/Images/EmotIcons/bm2.gif)
Posted 3/19/2012 8:29:57 PM |
![Supreme Being Supreme Being](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Supreme Being Supreme Being](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Supreme Being Supreme Being](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Supreme Being Supreme Being](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Supreme Being Supreme Being](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Supreme Being Supreme Being](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Supreme Being Supreme Being](Skins/CLTC20/Images/RankImages/BlockActive.gif)
The only way I can think of it working with the fuel caps is to sink a fuel cell down on both sides of the driveshaft. You would then need to re-route your exhaust which isn't a big deal.
The extra work comes in plumbing the system like a fuel injected truck running dual fuel tanks. This means dual pumps, switch over valves, duel fuel gauges etc. Basically running one main and one reserve. It also makes the car a bit unbalanced as the weight shifts from one side to the other.
You may be able to get it to work with a single tank that was only 6" tall, but even that would be a challenge
Building the BatBerry - Batmobile powered by BlackBerry ![Keaton](http://www.chickslovethecar.com/board/Skins/CLTC20/Images/EmotIcons/bm2.gif)
Posted 3/19/2012 8:42:26 PM |
Visits: 6,742
The alternative of putting it in the trunk does not work for you because your cabin is open up to the back of the trunk? ![Keaton](http://www.chickslovethecar.com/board/Skins/CLTC20/Images/EmotIcons/bm2.gif)
Posted 3/19/2012 8:47:48 PM |
Posted 3/19/2012 8:55:33 PM |
Visits: 6,742
Tim, what about opening the grills in the back? ![](http://cltc.co/Images/Uploads/Images/7a7518f4-12b0-41c4-b993-3c5c.bmp)
Posted 3/19/2012 10:03:46 PM |
Yeah that was another thing I was thinking about. I know in the onstar car they are open with mesh inserts. I just need a way to close them off when I'm washing the car or it's raining.
Posted 3/19/2012 10:24:53 PM |
Visits: 6,742
It can also serve to put a few of the rearview cameras
![Wink](http://www.chickslovethecar.com/board/Skins/CLTC20/Images/EmotIcons/Wink.gif)
Posted 3/19/2012 10:38:50 PM |
Posted 3/20/2012 6:28:15 AM |
Tim did you know how to weld before this car because you just do A great job even in tight areas.
Posted 3/20/2012 8:53:22 AM |
