«««89101112»»»
Posted 8/5/2007 4:45:04 PM
OK. So i've been having fun learning. Here's my very first weld (stick weld):
Pretty Nasty looking.  No, Very nasty.
Post #62200
Posted 8/5/2007 4:56:24 PM
Here's 1 week later with the steel I'll be using for my bottom frame/chassis. 50 times better than my first attempts, except stick welding round tubing is pretty damn hard.
Download the picture to read the details.
Post #62201
Posted 8/5/2007 5:11:11 PM
Here's me getting 100 times better.  I've taken these pieces to the local welder who's been doing it for 30 years.  He told me that I'm doing great and have gotten much better in a short time. He told me with the MIG, I should do really well.  I was happy to hear that.  As far as my weld strength goes - after securing it in my vise, I hit the piece on the right repeatedly so hard that it started to bend the square tube and my bead didn't crack at all.  if you look closely, you'll see the hammer hits.
The bottom frame will be this square tubing - 2" X 1 with .125 wall.
Post #62202
Posted 8/5/2007 8:18:25 PM
Posts: 5,397, Visits: 4,909
Hey Conrad, Looks like big improvements in just a short amount of time. Ok I'm just going to make one suggestions at the risk of irritating you. So take me wih a grain of salt. Look into the  possibility of using tubular steel.
The reason is the circle of a pipe is so much stronger the square tubing.  Yes I agree it is more detailing to cut and fit but the strength of your project is made so much stronger  Eighty percent of your time is used in fitting and only 20% is welding. Two people of equal welding abilities can start similar projects but the guy using superior tubular materials and tighter fitting of the pipe will have a tremendously stronger frame. Many dune buggies are made with mild steel tubular frames.  They can use mild steel because the use of tubular steel is so strong. Just a suggestion...BWD
Post #62208
Posted 8/5/2007 9:28:25 PM
Yes it has crossed my mind to use round tubes instead of square. a friend said that if you go to bend a square tube it bends easy due to the straightens of it all. the round tubing does not bend as easy. my square thoughts were brought on by seeing shots of the movie car under construction. I remember you saying that it doesn't have to be exactly like the movie car...yours certainly isn't. in fact, yours looks incredibly strong and protective and your taking so much thought to making it better. alot of your details are definitely eye opening. your making incredible improvements and constructing a very practical machine.
My goal here is to get my rolling chassis done by February. i think that's a good estimate.
So definitely not irritating. i know when to take advice. and i think I'll be taking it now thank you.
Post #62210
Posted 8/6/2007 8:10:01 AM
*pokes picture repeatedly* "....I wanna tumbler model."
Post #62212
Posted 8/7/2007 1:51:24 AM
Hey Conrad, I thought at one time about buying a tubular dune buggie frame and modifying it.  There's a four seater dune buggie thats called the Expedition.  i thought it might have a good base since it was already triangulated.  It was like $1500 fully welded on a jig to keep it straight.  Check it out at mooreparts.com  Then the front and back could be adapted to accept the duallies and front end.  Again just another idea....BWD
Post #62237
Posted 8/7/2007 1:23:20 PM
Hey I checked that site....no pictures! I called them and "nick" even agreed that it's stupid not to have pictures of ANY chassis you sell.  and Yes...way in the beginning stages of my project I contemplated getting a pre-fabbed chassis, however (you knew it was coming right...) the fact that I am capable of doing it myself makes this more of a passion for me and will make the finished result that much more special.  the only thing i wont be building myself is the engine and everything that makes the chassis and body move!
Please keep the ideas and suggestions coming...I do appreciate them.
Post #62248
Posted 8/7/2007 2:21:26 PM
awe , build the engine too, that would be fun , cuz everytime you hear it fire off its like, "yeah, i made it capable of doing that."
Post #62250
Posted 8/7/2007 3:22:57 PM
OK, howabout you build it for me haha just kidding! I dunno, that's a whole other ballgame, but it does sound fun.  Still want that buick V6 though.  can you say GNX? all kidding aside...would that be crazy? Using the Turbo V6? Is that engine smaller than a big block 8? is it possible to use for a Tumbler? What about the duallies? am I asking for trouble?
Post #62254
«««89101112»»»
All times are GMT -5:00, Time now is 9:19am
Execution: 0.484. 8 queries. Compression Disabled.
