More Tumbler Parts
««123»»
More Tumbler Parts Expand / Collapse
Posted 7/28/2008 5:02:25 PM
Last Login: 8/12/2008 12:45:06 PM
Posts: 41, Visits: 56
looks like it may be an adjustable fuel pressure regulator or a bypass or a switch/valve to pull fuel from dual fuel tanks, whatever it is I would suspect it to be fuel related because of the AN style fittings. The zinc colored object to the right of the silver box looks just like a high volume carter fuel pump.
Post #70759
Posted 7/29/2008 6:27:19 PM
Last Login: 1/2/2009 7:13:45 PM
Posts: 18, Visits: 85
In answer to your question about the first picture. The silver block looks like a primitive hydraulic manifold its got high pressure braded hoses coming form the left hand side (looks home made). The part its attached to (to the right) is possible a hydraulic pressure regulator/filter or even a pressure relief valve (PRV for short). I don't know much about the tumbler but I'm guessing it had some hydraulic systems?
Arnie
I will definatly be back
Post #70811
Posted 7/30/2008 10:44:35 AM
SMOOKY!
SMOOKY!
Last Login: Yesterday @ 3:19:24 PM
Posts: 1,047, Visits: 2,479
Hey ATOlink, dont know if it helps, but i can tell you that this bar actuates the flaps, thru a series of bars, and hiem joints, they can throw all 6 flaps up with the movement of one main bar.
Post #70866
Posted 7/30/2008 12:29:26 PM
SMOOKY!
SMOOKY!
Have you seen this?
http://flickr.com/photos/jaffathecake/2651218994/sizes/o/  it was on the side window of the Tumbler on display, IF its accurate, then that means that my 3D model is off.
Post #70869
Posted 7/30/2008 2:24:30 PM
Last Login: 12/31/2008 7:10:34 PM
Posts: 110, Visits: 1,266
Wow Shaggy that was a great find! That really puts a lot of guess work out of the picture. Also it's from the most reliable source, on the frikin Tumbler it's self!
Your the man
Post #70871
Posted 7/30/2008 2:42:34 PM
SMOOKY!
SMOOKY!
its amazing what you can find when you just flip thru flickr for the day
Post #70872
Posted 8/3/2008 1:51:18 AM
Last Login: Yesterday @ 11:58:17 PM
Posts: 308, Visits: 1,002
I just stumbled onto this thread, checked out the flickr pics. I'd never seen the picture with the stats until today. I converted Mtr's to inches, went out and measured my car. I found that my dimension betwen the inside front wheels was almost exact, and the dims between my inside rear wheels, were almost 31". the stats are 31.4960. I swear to god someone on a higher level must want me to build this thing, cause this has to be almost stupid clueless dooda luck.
Post #70996
Posted 8/3/2008 3:15:42 PM
